@ matze140 - The car does the same behavior in manual mode. It does the same thing like drive. In sports mode it does NOT disengage. Only in Drive and Manual Drive. In Sport mode or Manual Sport mode it works perfectly.
@CS_ i do not think there is any incompatibility, as my friend has a DQ500 from a pre-facelift RS3 on his car (RS3 365 BHP - gearbox code QLQ) and works perfectly. I have another friend with a G7R that used a DIESEL DQ500 gearbox from a Passat 2.0 BiTdi. Same thing. Gearbox works perfectly.
@MarkyMark , I can understand incompatibility between different manufacturers, but this conversion kit is used and is being sold by TVS Engineering in NL. So, I basically did the conversion myself and went to them for the software. The engineers from TVS have told me they have never seen this thing and that they are aware of that.
Martin Graf is a very good recommendation. Planning to visit him in autumn. However, HGP is very strict and the car does not use any of their packages. And i doubt it that he will help. But I will give him a visit.
@CS_ Gearbox into a coasting sailing mode, more or less. The behavior is quite weird because in the beginning it would just disengage completely and coast. Sail. REVO and Racingline, now just disengages, but less often.
Thank you all!
Car works You will not be able to tell that the gearbox was not there from factory. It is a top quality work. Both the installation, the software and the gearbox itself.
Only this disengagement problem is left.
I am starting to believe that this might be related with the RPMs on idle for the engine. Because in sports mode, it does not disengage. Because the idle RPMs are at 1100 RPMs. And in Drive mode the idle RPMs are at 750-800 RPMs.
So maybe this could be the problem?
My questions are:
1) how do I want to be able to do a trace session? Log data, etc? As the engineer from TVS said they need to understand why it is opening and closing the clutch pack. What causes it to do this. But I do not know how to troubleshoot this.
2) any other notices besides HGP?
3) Are there RS3 DAZA owners here? If yes, do you encounter the same issue? On a FB group, somebody with TTRS DAZA DAZA with gearbox code TCR do this thing .......
